I recently purchased a 1979 Owatonna Mustang 310 w/ a 14 HP Kohler 321-S motor. The 2nd owner bored engine out .030 prior to 2006. The 3rd owner replaced the ignition coil, breaker, condenser & Hi-Tension kit (Whatever that is??) in 2007. The filters & hydraulic fluid were changed in 2015 w/ new hoses. (I'm the 4th). I put a new carburetor & spark plug on it within the past week. Symptoms: The compression at the cylinder is 90 PSI (Should have checked that prior to spending $'s on it). Machine will start (a little hard) & run fine. I do 10 minutes or so of work with it & it conks out. Restarting is very hard if at all w/ bucket relieved of all pressure & drive clutch disengaged or until motor has cooled down (70 degrees was the minimum temperature outside). Is it time for a new motor? My thinking is motor should have at least 100 PSI minimum to keep this running. If this is the case I would like to upgrade my power. (19 HP minimum) Do I need to find a specific shaft size? Is it horizontal or vertical that I need? Any recommendations are welcome. Thank you.
