Labradigger1
- Joined
- Feb 19, 2019
- Messages
- 6
Hello all, first post here. Short story, bought the above mentioned skid steer and want to change hydro fluid. For the life of me I don't see a drain plug on the hydro resivoir tank. It is kind of dark where I'm working on it so I may be overlooking it. Bought it is needing a new engine and once home a set of points, condenser, plugs, oil and filter change, carb clean and fuel change took care of the engine. Left hydrostatic drive was not working, dissambled pump and lapped all parts. Nothing major I see wrong in the pump/motor except the 6210 2rs bearing inside the lower v pulley is toasted. Currently waiting on new seals to come snail mail for the 15 series pump/motor so figured I would change out fluids. Hydro fluid is severely water saturated and my plan is to changed it twice with a filter after reaching operating temps. Looks like pdf manuals I found for the gene 2500 shows atf type f or dextron for hydro fluid. When I removed the old hydro filter I was amazed at the amount of fiber like filth that was plugging the old filter, I'm guessing it was a rope/oakum type packing that broke loose from ram packing. Thanks for any assistance or "be sure to check out" items.
