M500 bobcat rings
Kish500
Any chance on finding rings and head gaskets for the M500 bobcat? I'm having issues finding any parts because all I have for an engine number is kholar k662. I'm missing a few numbers at the end. Does any know this eng number. Where I can get rings and pistons for the next size up? If anything a head gasket set so I can at least put her back together?
flyerdan
Jack's Small Engines has a cross reference that has 6 different versions of the K662 used, if you can match to your missing numbers you might be in luck.
Regardless of sub-model, the head gasket should be 275156-S and the ring set (std) 271508-S
Both are Kohler part numbers and give search results.
