Any experts out there that could answer a couple questions regarding the Variable Speed on my old Bobcat?
I started leaking oil all over the belt and frame, and am assuming it is coming from the drive clutch. I pulled it apart, and other than the O-Rings being a bit hard, I'm not seeing any issues, so I'd like to replace them and reassemble. Any tips on this, or things to look for? Is there some type of bleeding sequence when I reassemble?
I stopped in to the local Bobcat dealer, and they didn't have parts. Their main parts guy was supposed to call back, but seeing that I haven't heard from them, I'm guessing parts aren't available. Anyone know of a parts source for this? I'm striking out online.
Biggest question is looking at the parts diagram, there are two #24 O-rings required - See Image link at bottom. O-Ring #24 goes over the brass piston #9 to seal to the inner wall of #11, but I can't figure out where the second #24 goes. I just don't see another on mine. The only thing I can come up with is that it is used as a cushion for the piston to bump in to on full movement, and who ever had it apart before I got it didn't put it back in.
