Smokybanks
- Joined
- Apr 19, 2013
- Messages
- 8
Mike. Thanks for the info. I believe the problem is the lack of fuel supply. The unit will run at idle but will not respond to any increase of throttle and will just die. I removed the fuel filter and dumped a bunch of crud out. I removed the pickup tube and it was clear. I will install a new filter tomorrow along with a new fuel cap since the existing one is missing the check valve in the center. After I install the new filter I will check the fuel pump on the pressure side to see if I can observe flow of fuel. I will let you know what I find out
