Its a well used machine. It has what looks to be a non original Kohler M16s gas motor on it. It started and ran well. I was told it had been sitting outside for 7 months and had a lot of water in the crank case that turned out to be due to a cracked filler/dipstick tube. The new motor was put in with no thought to getting to the drain plugs so we sucked out the milkshake best we could and put some fresh oil in. I ran it for about 5 minutes around his lot then stopped to check things and found the leak/crack in the fill tube along with more milky foamy oil. I already have a plan involving a chunk of hose and my mini cutoff wheel to solve the drain problem. The throttle linkage is a complete hacked kludge that is so mangled it didnt really work. The key is behind the seat and the choke lever is under the seat so its sort of a challenge to get it started. The gas filler is just a hunk of hose extending up from the tank held with some wire through a hole in the rear cover. They wires to the key also tie to this hose. One of the axle seals may be leaking. Tires have tread on them but have some rather large cracks in the side walls. At the moment he has a new filler tube on order. He said he was asking $3200 but would sell it to me for $2900. He then knocked off $100 if I wanted to fix the oil tube myself. I may be able to get a few more off because of the axle seal. I also think cash will help, I was thinking $2500? Do you guys think that may be fair? Or am I crazy? I talked to a friend of mine that is a Kohler dealer and he said that motor is a slight evolution of their longtime standard 'K' series. Its a solid overbuilt unit that is hard to kill and not that expensive to rebuild if it needs it. Its a splash/dipper oil system so he does not think the water problem has hurt anything assuming it has not run that way. I guess that oil tube was a problem and they went back to their old design on the next generation. The carb is a known piece of crap that is not adjustable or supported by Kohler anymore and even had a hesitation issue when they were new. I guess the K series carter carb is the current one and they make a direct replacement for this vintage if I need it. I like how open the machine is. It looks like everything is fairly easy to work on. Thoughts? Comments?
