leaking drive motor LX885
hlw
The drive motors have a plate held on to the bottoom with small machine screws where oil is leaking from in a small stream. New Holland parts dont seem to show a motor breakdown so I can't see what this plate holds in. These are visible thru the mounting bolt access hole in the belly pan. Only one screw is accessible so I drilled a 1/2 inch hole to take out the second screw. Any ideas if the parts under this plate can be pulled out and an O ring replaced or would that be too simple. It looks like the end of a U joint cup under the plate and it is loose wnough to wiggle a bit but a bit afraid to try harder getting it out for fear of what all might follow.
Mike10
Yes, it is that simple. Remove the two screws, cover plate and the round disc. The oring is on the other side of the disc.
