lap bar sensor
woodwalker57
863 has 7.6 volts on signal wire to ground wire @ lap bar sensor coming from controller ...8 volts on source wire (normal).... took connectors loose @ sensor & controller... ohm out all 3 wires show good ....nothing to ground ( ground wire gets ground from controller)....checked all ground wires from battery good something shorted in controller ? not sure if this is true voltage hard to test Hall effect sensors
W
woodwalker57
well after working on this 863g for several months off and on ....replaced lap bar sensor with aftermarket brand ...still no light & several codes ....sent controller off to be fixed...reinstalled controller all codes cleared but still no lap bar light ...checked all grounds and wiring no problem found ...ordered new sensor & hardware from dealer ..installed now all is good...learn a lesson about aftermarket parts ..some work some don't
