Ketana
- Joined
- Jun 26, 2022
- Messages
- 21
I take it A/C dye isn't the right dye !
Will it damage the oil or pump components ?
I can return it if it's not what I need....I take it A/C dye isn't the right dye !
Can you send me a pic of the front and back. It will depend on what type a/c oil it is forI can return it if it's not what I need....
THANKS CHRISI wouldn't use that in the hydraulics. Ester absorbs water at a high rate and you could wind up with streaky oil and possibly clogged filter. Just get the right stuff and not worry about it messing something up
Thanks Russ ,much appreciatedI used the AutoPro UV dye,use 1 oz per 4 qts [ 4 liters]...russ
Thanks Chris, much appreciated.....This is what Russ is talking about. Atleast with this you can use it for all your fluid finding needs. It's $30 here, I haven't looked at amazon. Been a busy day.
Not trying to butt in Russ, I had the pic up already just hadn't sent it yet. Hope you get it found!!! I hate leaks and squeaks!!!
