I agree, the dealer has them and they are cheap. Without the cap, you risk getting not only dirt but water in your system! You need to make sure you have a cap on there or you risk damaging your hydraulic/hydrostatic system.I got one for our old 632 from the bobcat dealer right off the shelf. I think it was less than 10 bucks. replace it as soon as you can, the one on our machine when we got it was a black ball of dirt from never having been cleaned or changed. When you lift the boom or move the bucket a lot of air is sucked into the tank to replace the oil so you do need a good filter cap. Try online dealers if you are to far from one.
Jerry & Tazza, thanks a lot. I will head to the dealer immediately. I am a total noob to all things skid steer, so I very much appreciate straight up answers to my simple questions.I agree, the dealer has them and they are cheap. Without the cap, you risk getting not only dirt but water in your system! You need to make sure you have a cap on there or you risk damaging your hydraulic/hydrostatic system.
Don't feel bad edo102, if I had discovered this forum and read it before I bought my 1st bobcat I would never have bought the model I did and would have saved hundreds of dollars on repair and replacement . As it is though this forum has saved me a lot of money since. One thing in particular was the bronze filter in the port block, I have never seen it referred to anywhere else and even the dealer said a lot of people don't know about it. Ours was over 50% plugged ,check yours also.Jerry & Tazza, thanks a lot. I will head to the dealer immediately. I am a total noob to all things skid steer, so I very much appreciate straight up answers to my simple questions.
Ohh yes, that suction line filter! I got caught with that on my 731, but after the dealer finally figured it out and told me where to look, its the first thing i tell people with drive issues on 731 or older 743 machines.Don't feel bad edo102, if I had discovered this forum and read it before I bought my 1st bobcat I would never have bought the model I did and would have saved hundreds of dollars on repair and replacement . As it is though this forum has saved me a lot of money since. One thing in particular was the bronze filter in the port block, I have never seen it referred to anywhere else and even the dealer said a lot of people don't know about it. Ours was over 50% plugged ,check yours also.
Tazza, it was your posts on this filter that made me check ours. probably avoided a lot of problems and certainly improved operation of the machine. ThanksOhh yes, that suction line filter! I got caught with that on my 731, but after the dealer finally figured it out and told me where to look, its the first thing i tell people with drive issues on 731 or older 743 machines.
Glad my advise was helpful. Such a small filter causes so many problems!Tazza, it was your posts on this filter that made me check ours. probably avoided a lot of problems and certainly improved operation of the machine. Thanks
