New to skids and the site , apologize in advance for the ignorance and if I didn't post in the right place. Just picked up a case 1835b uniloader in rough shape but was supposed to work as it should . But it doesn't. Fixed quite a few problems already and had my fingers crossed that they were my problems. Parking brake was stuck on and linkage missing . Fabricated new parts and fixed that, all axle bearings and drive motor bearing were shot, replaced all those , leaking hoses , fixed, instrument panel not working , fixed , although now the charge psi light is on which leads me to my problem. Engine (diesel) runs fine, goes forward and reverse okay seems a little weak but I have nothing to compare it too. If I try to turn it's very hard for it to turn and it squeals , turning right is worse than left . When I turn to the right the controls chatter badly. Loader works fine up/ down and dump. Just got gauges today to check charge pressure by removing switch and I have zero charge pressure , unless I'm doing something wrong or the new test set is bad , but I doubt it. Also the hose leaving the charge pump seems to be cavatating badly . Bad charge pump or could it still be bad tandem pump and how do I tell? Thanks in advance
