How to get error codes 2004 s130 bobcat
malldogy
Hi guys new to the forum hoping for some info on how to get the error codes out of my clarck bobcat s130 when my bobcat starts it shuts down with a triangle with an exclamation mark and shuts the motor and hydraulics out any info in to reading the codes would me great guys regards dave
OldMachinist
Press and hold the lights button for 2 seconds, any codes will show in the hourmeter display.
Bobcatdan
Depending on which style dash you have, push and hold the head light button when the alarm sounds. The code is displayed in the hour meter. The code is only displayed as long as there is a fault. You need to check before you turn the key off. It will clear with the key off. If you have a newer dash, there is an info button. Use it to scroll threw the screens, codes is the last one. If there are no codes, it will say none. If the machine is shutting down, it is seeing low oil pressure, low hydraulic pressure or over heating.
