Help with new rubber track choice
Muzbomb
I have a Mustang MTL325 it is a big machine the current tracks are showing signs of replacement. I live in Canada have a small 2 acreage I use the machine mostly in winter for plowing snow and then maybe couple times rest of year just to touch up grade on my gravel drive way. What would be the best rubber track to buy for my use? I put around 40-60hours on in a year so not used a lot. What your guys thoughts
mrbb
I would suggest a track made for snow use then, this , is what you use machine mostly for, and it will give you way more traction than a dirt or even multi purpose designed track
only draw back to a snow track is they will wear faster when used on dirt, but you don't seem to use it much there, so, I think the pro's out weigh any cons for you! suggestions from me would be the camos snow track, if you can get in your size,
if not, these might be my second choice!
Prowler, there EXT or there Z model track,
