glitch
skidsteer.ca
Server Error in '/' Application.
Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails. Cannot insert the value NULL into column 'TotalPosts', table 'BobcatDNN.dbo.AdverFRM_Forums'; column does not allow nulls. UPDATE fails. The statement has been terminated. The statement has been terminated.
[FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif]Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Exception: Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails. Cannot insert the value NULL into column 'TotalPosts', table 'BobcatDNN.dbo.AdverFRM_Forums'; column does not allow nulls. UPDATE fails. The statement has been terminated. The statement has been terminated.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
Code:
[Exception: Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails.
The statement has been terminated.]
   AspNetForums.Data.SqlDataProvider.AddPost(Post postToAdd, String username) +1019
   AspNetForums.Posts.AddPost(Post postToAdd) +101
   AspNetForums.Controls.CreateEditPost.PostButton_Click(Object sender, EventArgs e) +1565
   System.Web.UI.WebControls.Button.OnClick(EventArgs e) +108
   System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +57
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +18
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +33
   System.Web.UI.Page.ProcessRequestMain() +1330
[/FONT]
