Well, if you believe you can mount it up, i'd go with the Kubota. Parts are easily available. If you go for the newer ones, like a V2203 they start quite easily, not sure how they go without a heater in below freezing climates. I'm from Australia, my V2203 powered machines fire right up, even when its really cold.lol, found the problem Tazza! no compression! Didn't need a tester either. Went to loosen the plate bolts that attach to the back of the motor and even with a 1/2" wrench the motor turns. It shouldn't turn that easy. Sooooo..... a motor swap is deffinately in the works. RJS
You can buy heaters that install into the head and warm the engine up to assist in cold starts.
The older Kubota engines don't start quite as easily, but they get there with a bit of a glow.
