machine addict
- Joined
- Dec 2, 2015
- Messages
- 30
Has anyone thought about changing their smaller high flow pump with a second standard flow pump? The two pumps are mounted inline as a two stage pump. The first is a 33cc standard flow capable of 24gpm and the second is 11cc for an additional 12gpm for a total of 33 to 35gpm. I don't see why the smaller secondary pump couldn't be replaced with 33cc pump like the first one and replace the bolts holding them together with longer ones. It should boost the flow into the low 40gpm range. The only problem I see is the first pump has a 3/4 hose and the second has a 5/8 hose. Also the machine arms are plumbed with 3/4 lines that might be a little small for the flow. If my idea would work someone could add 20%-30% more hydraulic HP for only $450 for the pump and a little more for bolts.
