joesmith123
- Joined
- Apr 21, 2024
- Messages
- 22
error code
fuse box, that wire was there when I opened it
There is one flash on the lift tilt light
I wish someone here could offer up some suggestions Joe. I have no experience with this issue.
I am very surprised there has been no one with any ideas.
I am not overly familiar with the T190.
If you press and hold the "Lights" button, do you get any codes?
It looks like the machine has had electrical problems in the past that have not been properly fixed. This will probably make it more difficult to diagnose and fix the machine.
I hope this is your issue. E
My computer antivirus started mid sentence, and I could not continue.Same, I must've spent 10 hours yesterday, testing voltages, reading through tons of old threads from all kinds of forums, watched tons of videos on how people deal with this
From what I remember, when I put 12 volt into that circuit that the bad solenoid is on, I do remember the computer flashing twice
And flashing twice meant Circuit voltage same as battery (12 volt)
And its not supposed to be, it should be lower than 12 volt
But in those videos where people bypass the BICS using a relay, are they not putting 12 volt on that circuit?
I still do not understand how they successfully did it with adding a 12 volt source
We'll see what happens tomorrow
I was saying even if you don't get many replies with some detective work you can often find someone that has had a similar issue.
It is a painstaking task reading through all the posts but much better than proceeding blindly.
The people here have a lot of great experience and knowledge to share.
Good luck! Be sure to let us know what happens.
When you press and hold the "Lights" button the codes will come up where the hour meter is. When you let go of the button the codes will come on one after another. There will probably be more than one code, so be ready to write them down.I was wondering how people were getting codes but all I know is to get to the screen that says "hydraulic lock valve open circuit"
I will try, "pressing and holding the lights button"
I thought the same, that the machine has had electrical problems but,
Once I read up on the fuse panel, that wire they have running is for lights of some kind
There really is not much going on in the fuse panel, mostly relays
The wiring seems overwhelming at first, but once you clean everything, you can start to understand and find the problem
