My first post and my first skidsteer. Recently bought a 2005 Bobcat S185. 3700 hours. Runs good for about 10 mins, then starves for fuel, smokes then stall. I have Bobcat excavators and Cummins trucks so diesels are familiar ground for me. I bled air out of system, it started and ran fine then same thing...repeated this a few times. New filter, checked pickup tube in tank-good,new fuel line from tank and tried feeding machine from temp tank. All same results. It will stay running if I keep pumping the primer bulb. My guess is the lift pump? It's obvious each time I bleed it I get it to run until I lose that pressure then restore pressure manually with the bulb. Any help will keep me from jamming the little lady in with the motor to keep ithe fuel to it.
