I'm a new owner of a old Monroe 600. Worked great for a few weeks, but started to die when under load. Has gotten worse in past week of daily use - does not want to do anything more than idle after warmed up. When troubleshooting, I discovered that it was never making full power (pushing governor manually).
It will work fine for the first 15-20 minutes (about 75% power) where I can at least get the bucket into a pile of dirt. After a short time, then the engine will die while trying to go into the same dirt pile, then eventually will die by simply driving. Seems to stay running if I quickly pull it back to idle - can drive but not steer without killing engine. Once it gets to this point, it will not go full throttle without choking out.
I have checked the air filter - dirty but still looks like it has good air flow. Fuel filter is clear by blowing through it. I'm stumped as if was a fuel or air problem, the issue would be persistent when initially started. Choke works properly. Seems like something happens when it warms up.
Any help is greatly appreciated!
