Hey All, well it looks like Winter may be over here in Missouri, although it was 24 last night. Anyway I got all my parts in and ready to put this thing back together. I went looking for the gas tank, and removed the floor plate, but.... no gas tank, couldn't find it. I knew the gas went somewhere when i poured it in, but it was a mystery. Time for a scooby snack and some sloothing. I finally figured out there was about 13 inches of dirt and debris hiding it. Got the ol shop vac and started sucking out the dirt, there was so much in there, it was like working in an dig site. Different layers of strata the lower I went. First leaves, then dirt. Next came regular gravel. Going deeper i found some white stuff that looked like coral, no idea what it was. On down, a layer of what I believe is coal, yep coal. Must be from West Virginia. Finally at the very bottom, about 2" of grey clay, at least i think that is what it was, or a decomposed Roswell Alien. Then Eureka! I finally found the gas tank, there it was, in all its rusty glory. During that process, I emptied 3 of the large shop vacs full of stuff. I found a screwdriver, paring knife (maybe they cut up apples while cat'n around) some steel woolish material, some poly fiber stuffing stuff, 2 springs, broken glass, white coral and a little tiny glass bottle that said Burrett's Liquid Color. No wonder the gas gauge didn't work, there is no wire going to it, and it is rusted all to hell. I wanted to take it out, but it looks to be a daunting task. I think i will just steam clean it, and put rust inhibitor stuff on it, and gauge my fuel level like i did before....It just runs out ;-) So then mother nature decides we haven't had enough rain in a while, and dumps over an inch overnight, and I discovered there was no drain holes below that plate where all the dirt was. I have a new mini swim'n pool. So I got the drill, and made me one, draining that pool of rainbow colored water. So, now, its time to finally replace the Spline drive on the Hydraulic Pump. I have no Clue how to do that. I have a copy of the dealers service manual, and they leave that part out. They show me how to change the piston rings in the dam engine, how to fill up the hydraulic system with air for testing, and how to test the voltage regulator, but not a hint at removing that little sprocket. So, Does anyone have a guess? The new one is threaded, and has a keyway. The old one I don't know. I took the center bolt out, but can't figure it out. No keyway that I can see so far. Whats yalls best guess, i don't want to break anything, so the big hammer stays away for now. One funny thing, the manual also said, "to remove the blower shroud, you must remove the flywheel". Well, that was news to me, as i somehow got it off while the flywheel is still on. Guess I should have read the manual first. The other interesting thing while reading the manual, The lever I thought was a brake is shown as a High/Low speed selector. On my Right hand side behind the throttle. I just thought the brakes didn't work. So now, i wonder where the brakes are? Thanks guys! I have some pics coming soon, as soon as i find another hosting site, I ain't paying nobody to host pics. Cheers!
