I got to find where the relays are at.the contacts on the fuel soleoud relay check those
if not by pass it with a paper clip
I've got a electric fuel pump but I'm not sure where the wires are or how to connect them.could be your fuep pump leaking pput a etric fuel pump on should
solve you issue i did that works fine i own three machinis
I've got an electric fuel pump but not sure how to connect it.could be your fuep pump leaking pput a etric fuel pump on should
Yes it did,had it for a few years.i dont know history did it run before what happen
Will give that a try, thanks!u have put the pum in two wires black is ground to the frame other one
is hot to red with a on and off switch or find a fuse thats hot with key on stick it in therir
Thanks for your reply! If you could contact your mechanic after he gets back than that would be great, thanks!The fuel rack must move, it sounds to me that your pumps are stuck in the no fuel delivery position.
These engines run 4 injector pumps, for one to be bad is a possibility, but all 4, it has to be a common issue, and i'd suspect the throttle control to the pumps.
As i mentioned, i have never worked on one, but i do know there is a rack that joins all 4 injectors together. It's possible one injector is stuck, making none move. I also don't know how the fuel shut off solenoid works, but with it removed, you should be able to move the part it pushes on and it will move, the solenoid will push it in one direction to shut the fuel off.
I hope some of that makes sense.
The mechanic we have that works on these engines is not back till the first week of January, if we don't make progress in here, i can always hit him up for you when he is back
Checked it earlier,no error code.i dont get it your rack opens u say u get fuel to the injectors cranks normal u must
have codes whats the code
