I think I may have found my problem. After tazza said maybe a lazy lift pump, I went back tot he tank to check my pick up and discharge line. Then i went to test the lift pump. When i pull off the suction line, there is a piece between the line and the pump, Is this a check valve? It has a ball and spring inside anyway. That was all full of junk. I cleaned it out and tested the pressure which I guess to be bewtween 5 and 6 psi. Dacott, if it helps, my service manual states that lift pump pressure should be a minimun of 4.5 psi, so I would figure you are in the range as well. You may want to check the lines and check valve as well. I dont know for sure if I found my issue as I havent run it enough to find out, but for a short spin, it actually seems to run a little smoother.
