bobcat 630
bingo
going to pull a wisconsin engine from a bobcat 630. It has a tapered shaft connected to the pump. Does any one know if this will just slip out when I slide the engine out.(looks like it sits on a plate that slides out with the engine). or do i need to take any thing loose from that end before I slide out the engine... thanks
mrfixitpaul
I just pulled a kohler out of a 530, with tapered shaft. The coupler was just a spline, nothing to loose , just slide out. I'm not sure if the 630 coupler is the same, but all the other inline bobcats I've seen just slide out.
B
bingo
Thanks that should make it a little easier to pull, and install
