battery leakage while machine off
mrbb
UPdate, problem resolved;
Turns out it was the control panel run button contact .
as a summary started out thinking the battery was being drained, then a weak ground, or alternator. all that ruled out and still it would not activate the panel when run was pushed so that it would start.
But, put a charger on it at 6 amps for 10 seconds and it would allow it to activate so the start button could be used.
I sent the panels to have checked and this was the issue, put it on and it has worked since.
dang little button contact cost me a lot of time and about $900 total with repair, and having a mobile come check other things.
education is priceless! but its better to learn from others.
hope this saves someone else some time down the road.
glad you figured out your issue, nothing more frustrating than having an issue and not able to find it,
and thanks for adding a update with a resolution, so many posts never get this.
Now best of luck on issue free use for a long time now for you!
