ok babcatdan, pulled the old belt and the new one is the wrong size by 2 inches short. cleaned and reinstalled the old belt. tensioner pointer went to 1 oclock when I released it. I had to to reinstall the old belt, I couldn't get the tensioner pointer to move. I couldn't feel any movement in the bearing /belt tension so I used a 2 foot pry bar and had daughter tighten down the tensioner bolt while I pried down on the tensioner until there was no more give in the belt. when running the belt vibrates just a hair of a dog, so I think I have it about right. I guessing that the spring in the tensioner is shot or frozen. I sprayed the rear spring and mech with some pb blaster to see if I could get it to loosen, but didn't see or feel any changes. I did notice that the tensioner bearing was just a hair loose, is this normal? On a car, I would say that it is on it's way out if I can't adjust it. So, are the tensioner bearings adjustable? Belt does have some wear fractures in between the knobby, so it is time to replace it. Back side of the belt still looks new. Still makes the same noise, arghhh.......Waiting on the new belt again.......
