Roses4nikkkie
- Joined
- Aug 17, 2014
- Messages
- 16
replaced the hydraulic control lift valve and nothing really stuck and need this machine to do much needed work at home please help if possible. Thank you Mike & Nicole
moves a inch lift and tilt nothing else very stuck on this any help would be great i do know some stuff had the machine 10 yrs and just had it serviced and now this really stuckCan you elaborate. Does the pedal move does it try to move or does the machine sound like its trying. Could be bad seal in cylinder pushing oil through.
Define stuck. It can mean that the brake is stuck on making the machine not move.moves a inch lift and tilt nothing else very stuck on this any help would be great i do know some stuff had the machine 10 yrs and just had it serviced and now this really stuck
only moving about a inch lift and tilt then stops dosent sound like anything just wont keep going stops just after it start the machine is running and everything else seems fine just dont know what the problem is. it wants to move then stopsDefine stuck. It can mean that the brake is stuck on making the machine not move.
Are you saying that the pedal is not making the arms lift?
If that is what you are saying, there is a lift lock solenoid that prevents the lift arms from moving if the computer doesn't think you are in the seat. Does this sound like what is wrong?
i dont have that safty feature on this machine the lift arm is stuck up and the bucket is not tiltingonly moving about a inch lift and tilt then stops dosent sound like anything just wont keep going stops just after it start the machine is running and everything else seems fine just dont know what the problem is. it wants to move then stops
Are you sure your machine doesn't have it? that model had a lift lock solenoid as standard equipment.i dont have that safty feature on this machine the lift arm is stuck up and the bucket is not tilting
Let's start from the beginning.Are you sure your machine doesn't have it? that model had a lift lock solenoid as standard equipment.
