Untill then after sitting try jiggeling the levers before startingPick all wheels off the ground and block it up good and ajust the steering linkage
If you disengage the brake before starting can help reduce or prevent the grinding noise.Untill then after sitting try jiggeling the levers before starting
this is what the guys are referring to its called creep . at full throttle. brake released unit should sit still. should be able to drive forward handels should snap back to neutral. this can be equated to your old standard ford truck like trying to start in gear without pushing the clutch. gonna get herky jerky.If you disengage the brake before starting can help reduce or prevent the grinding noise.
Getting the neutral adjustment right is not always easy, it can take some time to get right.
