Not sure this will help, but adjusting the timing is pretty easy. The injector pump is held in place with 3 bolts/nuts. First, scribe a line on the pump and the mounting flange so you can keep track of what you're doing. Loosen the bolts and use a huge set of pliers to just rotate the pump, then tighten it back down. I've changed mine by about 1/16" and it makes a noticeable difference. Forget which advances and which way retards. Just a suggestion: start by rotating it 1/16 inch in one direction and see if it helps. The guy who showed me this was doing it "hot" with the engine running. I think he left the bolts snug so it was pretty hard to rotate, but I could hear the engine run smoother as he advanced the timing. I think this was about 100 hrs after a timing belt change, so I think as it wore in, it retarded the timing slightly. --- Now, did you pull the engine and leave the pump in place as Tazza suggested? I need to pull it and do at least a ring job. I think I'm supposed to use a lifting bracket, but maybe I can get by with just bolting a chain on the engine and using a hyd lift/boom to lift it slightly and roll it out backwards. How did you remove it?
---Bobbie G
