743 Speed Adjustment
lancinator
I just put a 2203 engine in, it runs great, starts great. I had one more problem I wanted to fix. When you are running full tilt the left side wants to run a little faster than the right side. Is there a simple flow control adjustment to take care of this problem?
OldMachinist
Could be that the steering linkage just needs to be adjusted. If that doesn't help then likely one side of the system has more wear than the other. You could try swapping the drive motors side to side to see if the problem follows.
antfarmer2
Yes just ease up on your left side as needed
