I've seen spin on filter plates on engines that have just had a close nipple for the filter to thread on, you might check and see if the stripped part will come out. Check and see if the filter is a pipe thread, it might be a real simple fix.Mitsubishi dealer only would be my thoughts
If the nipple is just straight fully threaded you can buy a piece of metric threaded rod(McMaster Carr part #98833A460) and make one or if you know someone with a lathe they could make one. The thread for your filter should be 20mm dia. by 1.5mm pitch.I've seen spin on filter plates on engines that have just had a close nipple for the filter to thread on, you might check and see if the stripped part will come out. Check and see if the filter is a pipe thread, it might be a real simple fix.
The Mitsubishi 4G32 1.6L engine was used in several automobiles so you might have some luck at a salvage yard. Here are some of the model that used it.If the nipple is just straight fully threaded you can buy a piece of metric threaded rod(McMaster Carr part #98833A460) and make one or if you know someone with a lathe they could make one. The thread for your filter should be 20mm dia. by 1.5mm pitch.
I'll give the salvage yard idea a try after the holidays-----unfortunately the stripped threads aren't on a separate nipple rather it is a single casting. Thanks everyone for the replies. I'll follow up on what I find at the salvage yard.The Mitsubishi 4G32 1.6L engine was used in several automobiles so you might have some luck at a salvage yard. Here are some of the model that used it.
Dodge Colt
Eagle Vista
Plymouth Arrow
Mitsubushi Galant, Lancer, Sigma, L300, Celeste, Sapporo
Hyundai Pony, Stellar
Must be a "bolt on" to the block though?I'll give the salvage yard idea a try after the holidays-----unfortunately the stripped threads aren't on a separate nipple rather it is a single casting. Thanks everyone for the replies. I'll follow up on what I find at the salvage yard.
yes the casting just bolts on to the block.Must be a "bolt on" to the block though?
