if this landed in my lap i would do a direct pump test on all three. i would dial in all pressures to high side of spec. and than check operation.
The original pump was foaming from a bad E seal, but had some wear. However system was not contaminated and the was plenty of flow to the pumps suction. Customer decided on a new pump over reseal job on 2800 hour pump. No hard parts are available.
New pump foamy oil problem gone, but only made pressure on 1 section. The other 2 had none. I could stop the flow with my thumb over the output line,(so pointless to flow test) basically the oil was running via gravity from the tank through the pump on section 2 and three, starting the engine just sped this process up a bit.
Unfortunately I had to leave it in the hand of a mechanic friend, as I have taken a new job 1100 miles away, 2 weeks out, 1 back home.
So I just called him so I could update you all. Drum roll.... when you turn the input shaft on the pump, sections 2 and 3 do not rotate.
Between the pump sections (I pulled the old pump down) are short splined drive shafts to continue the drive to the next section, one must have be left out in assembly.
So Fish you hit the nail on the head. My apologies for mis reading what you said earlier.
Dave does not have the unit up yet, because when I crossed the engine lube filter from Baldwin to Wix they gave me the wrong part (bad wix! Screams "why me", can't catch a break, and I even double check the # because the filter was a bit smaller, the cross reference is wrong) so he is just waiting on a lube filter and has to put the counter weight back on. Pretty sure it will be all good now.
This "may" be why I won't miss being a mechanic at my new job as a operator.. only a operator, dont even touch the dip stick!!! (Union)
Although I gave the fuel/lube guys a heads up on low hyd oil on my loader and the prick had the nerve to say "just stand back and let us do our job"
I just about told him to STFU and pay attention, your talking to a licensed mechanic "pumpboy", but I'm new there , so I though I had better behave myself. (and I have a few weeks to go b4 I write the goverment test)
I got to meet the equipment manager the next day, he is a great guy and we hit it off. In a few minutes of talking he was glad to have me and we are on the same page.
And I'm sure the mechanic thing is like a disease, and I'll be back at it at some point, hopefully with this new company.
