259b3 Drive motor leaking
HEAVYD
Have a 13 259B3 with 1400hrs starting to leak gear oil from the drive motor I was just curious if there was a vent on these drive motors, Reason I am asking is because when I remove the Fill/Drain plug I have pressure built up and it could be causing to blow out that seal... Another question I have is this seal doable or do I need some special tools to install it.. Any Info helps thanks
knogen
Need a big spanner socket, torque nut to 2900ft lbs Best to go to dealer If bearing is worn have to replace motor Bearing is part of hub and not replaceable
H
HEAVYD
Thanks for the Info 2900ft lbs thats a big wow!
kroog
Man how long is your breaker bar to make that setting?
The leak is usually caused by the duo-cone seal. Best to remove the motor and take to your local dealer they have special tooling for this job.
