2018 SSV65
Fbplayer1011
Hello,
New here looking for some help diagnosing a problem on a 2018 SSV65.
The Lift arm footpedal sticks intermittenty when raising and lowering the arms. With alittle wiggling of the foot pedal you can get it to operate freely. I took apart the foot pedal and made sure everything was free and it looked fine. The buffer looked alittle rotten but not sure if thats the cause of the problem. Any ideas? Do the Spool's in the valve body cause this? Its got 2900 hours and everything else runs smooth.
Thank you!
F
Fbplayer1011
I replaced the Damper assembly on the foot pedal and that seems to have fixed the problem so far, the old damper was not smooth moving and likely causing the sticking.
