A easy way to install a remote grease nipple is to use a grease gun hose, a 1/8 NPT coupler and a grease fitting. However you do it, any 1/8 NPT fitting will fit.Every grease fitting I've seen on a Bobcat was 1/8"-27 NPT. Pull one out and measure it it should be about .365" on the small end and taper up to about .390" diameter
You at Nashville, IL like eating at the truck stop at exit 50Every grease fitting I've seen on a Bobcat was 1/8"-27 NPT. Pull one out and measure it it should be about .365" on the small end and taper up to about .390" diameter
You're talking about Little Nashville. I've never eaten there even thou I live about 9 miles south.You at Nashville, IL like eating at the truck stop at exit 50
Grease Zerks are also available with standard 1/4 - 28 threads. These are nice if you have a smaller area to work with. I just built an attachment and I used mostly the 1/8 - 27 npt, but in two spots I needed to use the 1/4 - 28 set up.You're talking about Little Nashville. I've never eaten there even thou I live about 9 miles south.
