I just bought this machine today. I like it a whole lot, but it will not stop beeping. While beeping, it flashes a symbol that looks to indicate a hydraulic or pump or pressure problem. The 'symbol' that flashes is an image that looks like two gears rotating with two arrows point through them. It looks as if it is showing fluid flow through the two gears; hence the idea of "hydraulic" / "pump" / "pressure" related issue. It seems to beep in a sequence that I have yet to understand. I did unplug the hydraulic pressure sensor & then it beeped more often & with a different sequence. Any help would be great. Thanks guys.
