1990 bobcat
Martinhoracio1965
hello I have a 1990 843b bobcat it has a Isuzu engine, it was working great until I flipped forward I started having no power at least that's what it looks like its happening, two injectors were fixed cleaned the tank cleaned the lines, white smoke comes out, I move the accelerator lever forward and it doesnot accelerate, there is fuid the manifold but this machinne has no way of adjusting the injectors at first I thought ididnt put them properly but the problem persists any ideas? im in san Antonio tx is there a mechanic here that I can see? thank you for any help I get bye and have a wonderfull day.
OldMachinist
How far forward did you flip it and what did the engine do with it flipped? I'm wondering if when it flipped one or more of the cylinders filled with oil and bent a rod.
As OM has said, cylinders can fill with oil if the machine flipps over. The correct procedure is to remove glow plugs or injectors and spin the engine over after the machine is put up rite to remove any oil that may have gotten in.
If you don't do that, you rish hydraulic lock which can bend rods or worst case, breaks rods and punch them through the block.
