twostroketom
- Joined
- Feb 10, 2021
- Messages
- 2
I have a 1980 Bobcat 825 skid steer that we use pretty regularly. It has always worked really well until recently I went out to plow snow and the drive coupler spline stripped out. It is a constant velocity joint that bolts to the flywheel then the other end is a splined yoke that slips onto the splined pump shaft. The splines are worn bad on the part that bolts to the pump shaft, the splines on the yoke side are completely stripped out, and the constant velocity joint is trashed as well. I need this whole unit with the splined yoke and splined piece that goes on the pump shaft. I went to my local Bobcat dealer and they told my they can no longer get parts for my machine. Anyone know if this complete coupler is available anywhere or if a fabrication shop could make this coupler? Any help appreciated. Thanks in advance for your help.
Tom.
Tom.
