Hi,I have an s185 with codes 5-15..5-14..4-21.The machine was running fine,parked it for the night and the work lights were on the next morning,no key in the switch.I found moisture in the fuse box in front of the seat,cleaned it up blew it out and replaced all fuses and relays.The led read out on the left dash panel would not work after that so I could not read the codes,replaced that and now chasing codes,I checked the engine oil psi and charge psi with a gauge and they were good(270 charge and 65 oil psi)so I replaced the senders,still same codes.The belt is tight and I checked all of the grounds that I can find.Any ideas I am stumped
