763 tilt valve leaking
huck65
I have a 763 and the tilt valve sticks when the pedal is pushed full foward [dumping bucket], it sticks and bucket does not move. If I bring it back about half way bucket dumps fine. I have replaced the seal and inspected the spool and did not see any damage. I have lifted the cab with it running and it is shooting fluid out the little hole in the cap only when valve is in the full tilt [stuck] position. All other hydraulic functions are working fine. Does anyone have any suggestions.
Well I figured it out, the allen bolt that holds the centering spring and washers had come loose and backed out. Torqued it down and reassembled and all is well.
Glad it was an easy fix.
