So this thing has more issues than news weekly. Already replaced a bunch of cables, starter, flywheel but I'm not familiar with hydraulic systems. My skidsteer leaks about 5 gallons ATF within a few hours. So it's kinda becoming expensive and messy to run. Both couplings have class 3 leaks right where it connects to the bucket holder...thing (expect lots of technical terms like this). It leaves trails of fluid at times and if I leave the bucket up overnight it will fall by morning. Thankfully I also took pictures. I think this is the kit I need to fit it but I'm not positive. My mechanical skills don't transfer over to most of this stuff so I'm learning as I go. http://www.ebay.com/itm/New-Holland-L778-Skid-Steer-Tilt-Bucket-Cylinder-Seal-Kit-/161237947473?pt=BI_Heavy_Equipment_Parts&hash=item258a87d451 http://oi59.tinypic.com/2efusud.jpg you can see the leak puddling up in this pic http://oi62.tinypic.com/iqc1te.jpg The next leak comes from the right side (transmission?) again pics. I took the cover off to find the leak and below is what I found. Not sure if that looks right, especially the pepto color. I did drain my radiator last night as well but I did see pepto looking juices around before emptying the radiator. I'm not sure if this housing is supposed to be filled with atf like this full time and the leak is coming from a bad seal around the cover itself or what? http://oi60.tinypic.com/24fy9vb.jpg I obviously don't have a manual yet, got one on order.
