pump adapter
720cat
I have a 720 bobcat my adapter to pump is bad and im looking for a replacment ....not so easy so I found this site on line.I gotta say here is a wealth of imfo on this site.so anybody got thoughts on where to get it or other means of fixing it...please open to suggest ions
I have mount to flywheel .I need sleeve yoke and u joints.I have part numbers from bobcat but no cross refrance for univ parts
Sadly some of that will have to come from the dealer. LPS do have the u-joints, as will bearing companies. The adaptors are not an off the shelf item.......
720cat
Thanks tazza I had a feeling this was going to be the case but I had to give it a shot im due for some kind of good news.seems like everything is breaking down at once...stresssss.
720cat
So wats up in bobcat land any leads on my pump adapter.I know bobcat has it.but.640 to 700 dollars.tazza was right about the ankles
Tazza finally bit the bullet new u joint and adapter. Up and running thanks for your help
