Daewoo skid steer
Mayer075
Trying to swap motors from one machine to another. Is there a release anywhere on the machine to make it freewheel so it can be pushed once the motor is out?
That is a question that comes up a lot.
Unfortunately, in most cases, no, you are stuck with dragging the machine around to move it. You may want to do a search in the Daewoo section to verify this.
What a lot of people do is wet down the area that the machine is to be dragged across to at least reduce the friction. HTH.
mahans7
The only way I know of the get the machine to roll freely is to disconnect the drive chains from the motors.
Might want to look at this post with novel ways to move a skidsteer.
http://www.skidsteerforum.com/DesktopDefault.aspx?tabid=54&frmView=ShowPost&PostID=60966
