Case  > General  > Case SR 220 Skid steer Wont start
 Author Thread: Case SR 220 Skid steer Wont start
CaseSR220 is not online. Last active: 4/29/2012 2:09:55 PM CaseSR220
Posted: 04/29/2012 11:01 AM
I recently ran my skid steer out of fuel..after filling up again it wouldnt start. Does anyone what i need to do to get it to start again..PLEASE HELP! Thanks
OldMachinist is not online. Last active: 5/21/2013 3:11:44 PM OldMachinist
Re: Case SR 220 Skid steer Wont start
Posted: 04/29/2012 01:36 PM
Don't know about a Case but on a Bobcat there is a bleeder screw on the fuel filter housing that you open and then squeeze the primer bulb until you get a good flow. If there's no system like that on yours you can try taking the fuel filter off and filling the filter with clean fuel, reinstall and try again.
Bobcat 453F ,Loegering steel tracks, Grouser steel tracks, 48" Dirt bucket, 48" toothed bucket, grapple bucket, 72" hydraulic vee snow plow and utility forks, 1954 Ford 860, 1952 Allis Chalmers CA, 1947 Case SC, Nashville IL USA
Posted: 04/29/2012 02:14 PM
You may also have to crack open the fuel lines at each injector and have someone crank it over until you have fuel at each one and then retighten them.
wmgeorge is not online. Last active: 6/26/2012 1:30:13 PM wmgeorge
Posted: 05/05/2012 02:34 PM
What he said. I ran out of fuel one time, actually had it shut off the clean the filter and forget to turn it on. Got by with just bleeding at the pump. That was my John Deere 650. Never run out of fuel with a diesel. :(
Page 1 of 1
Forums  > Case  > General  > Case SR 220 Skid steer Wont start
