whats this ?
destro
On shut down ; the code says the left swash plate is out of balance. What is a swash plate
jerry
Swash plate is the part of the hydro pump that varies your speed and direction. Simple when you see it but hard to describe. It holds the pistons and controls how much oil they can gulp in and which direction its going when it comes out. How it could get out of balance without breaking I have no idea.
jerry
It may mean that the position of the swash plate is not referenced properly with the direction control if you have something other than stick controls.
It must have hand controls, possibly a recalibration will cure the issue, if not, it may need a new actuator and a trip to the dealer to get programmed.....
