there are quite a few ways to skin a cat , what do you have to work with , another Bobcat with forks , an excavator or a forklift , or do you want to do it strickly by hand , which you will need a pry bar , a 2 x 4 , a way to jack the machine off the ground and a operator or if you are all alone a broom stick to stick thru the cage and active the travel lever , put the 2 x4 in between the front idler and the track after you take out the bleeder screw and remove the bottom bolt completely from the front plate on side the track frame , if not the bolt sticks thru the frame and the adjuster will hit it and not allow it to go all the way back , roll the track and the 2x4 will lift the track up on top the idle , it will loosen the track and make it easy to put a bar thru a hole in the middle of the track and pry against the idler as it is turned and it will jump off , use the bar in between the sprocket and the track to get it off there , you need to have it ja cked up high enough to clear the track guides under the rear idlerForgot to mention I am going to replace seals in track adjuster also at same time. I need to remove track completely. Thanks for quick idea on the come along.
thanks for the input! we did it the manual way and it worked great. now I know how to do it it is actually not to bad.there are quite a few ways to skin a cat , what do you have to work with , another Bobcat with forks , an excavator or a forklift , or do you want to do it strickly by hand , which you will need a pry bar , a 2 x 4 , a way to jack the machine off the ground and a operator or if you are all alone a broom stick to stick thru the cage and active the travel lever , put the 2 x4 in between the front idler and the track after you take out the bleeder screw and remove the bottom bolt completely from the front plate on side the track frame , if not the bolt sticks thru the frame and the adjuster will hit it and not allow it to go all the way back , roll the track and the 2x4 will lift the track up on top the idle , it will loosen the track and make it easy to put a bar thru a hole in the middle of the track and pry against the idler as it is turned and it will jump off , use the bar in between the sprocket and the track to get it off there , you need to have it ja cked up high enough to clear the track guides under the rear idler
