Would a tool review be a good topic , I got a new tool for Christmas , my Girl friend is super , she seen I had been looking at a Craftsman Twin Cutter saw and she got it for me , today was the first time I got to use it , it is awsome , it's got two 6 1/2 inch carbide blades that spin opposite of each other and is built like a side grinder I was building a shelf to hold part bins , and cuttting 16" sheetmetal panels about 1/8" thick as smooths as silk , no vibration or kick back , straight smooth cut with no grinder dressing up needed ------- I also used to fab up an aluminum boat bracket and cutting aluminum is like it ain't even there , it worked well to put a gouge at the joint to be welded , and can be used like a grinder to cut down and shape the material ------------------another useful tool I got recently is the Fien MultiTool , it looks like a side grinder and has an osculating shaft that holds saw blades , sanding attachmets , cutter blades/scrapers and rasp/file heads , the flat cutter blade then the sander is the most unbelievable gasket remover I have ever seen , the saw blades cut steel very well in tight spots but they are expensive , even e bay is no deal on blades ---------------the bottom as fallen out of work , things are slowing down big time giving alot of time to do things that never get down
