The coolant is purple it is propylene glycol. You need a refracometer to test it. You should be able to find it a auto supply store. From what I have heard you should not mix it with the green it will not mix well and could cause problems.What kind of coolant does the newer bobcats use? You mean I can't taste it with my tongue anymore??? That's depressing![]()
Tester for propylene glycolThe coolant is purple it is propylene glycol. You need a refracometer to test it. You should be able to find it a auto supply store. From what I have heard you should not mix it with the green it will not mix well and could cause problems.
