Feb 18, 2017 #2 D djack Active member Joined May 22, 2009 Messages 25 What will shut a T 590 down with no codes, have one to check monday, I guess it restarts, runs a couple of minutes then shuts with the active warning light flashing?
Feb 21, 2017 #3 SkidRoe Well-known member Joined Dec 10, 2009 Messages 1,885 I did a quick edit to add a subject line for you. Cheers - SR
Feb 21, 2017 #4 T Tazza Moderator Staff member Joined Dec 7, 2004 Messages 16,836 SkidRoe said: I did a quick edit to add a subject line for you. Cheers - SR Click to expand... Bad battery or cable?
Mar 2, 2017 #5 OP OP D djack Active member Joined May 22, 2009 Messages 25 Tazza said: Bad battery or cable? Click to expand... Thanks for the replies, turned out to be an egr motor, There are some codes the panel wont display, need the bobcat diagnostic software.
