Thank youMany later machines have the high flow button on the panel, whether the actual high flow pump is installed or not. On mine, if I push the high flow button, the light above it doesn't come on, thus verifying that mine is not high flow. You can also call the Melroe/Bobcat plant at 701-678-6165 with your serial number and they can tell you how the machine was configured when it shipped from the plant. ---Bobbie-G
I looked at the pump earlier & didn't think it was hi flow; but my light would light up when you mashed the button; I called & they confirmed it isn't hi flowThank you
Thanks for the feedback. I was sure that light would not light up if not high flow. Ratz. Ya jus' can't trust anything any more! ---Bobbie-GI looked at the pump earlier & didn't think it was hi flow; but my light would light up when you mashed the button; I called & they confirmed it isn't hi flow
"You can also call the Melroe/Bobcat plant at 701-678-6165 with your serial number and they can tell you how the machine was configured when it shipped from the plant. Smiley ---Bobbie-G" This was very helpful for me and just wanted to say thank you!Many later machines have the high flow button on the panel, whether the actual high flow pump is installed or not. On mine, if I push the high flow button, the light above it doesn't come on, thus verifying that mine is not high flow. You can also call the Melroe/Bobcat plant at 701-678-6165 with your serial number and they can tell you how the machine was configured when it shipped from the plant. ---Bobbie-G
