I have a slow hydraulic leak that happens when i run the bobcat for a a couple hours and then let it sit. The fluid is leaking from the rear round port holes on either side. I have lifted the cab and pressure washed the interior. I replaced the hose that comes out of the hydraulic tank and that didn't seem to stop it. I see no visible dripping from any of the hoses. This is frustrating because in about 5 days 5 gallons of hydro fluid is going to be on the ground soaking into the dirt. Is this a leak i won't be able to visibly see leaking? Can I put a dye in the oil to see color better and what kind would i use. The bobcat has 5000 hrs on it. Any help would be appreciated. Brian
